Originally Posted by Andrewh
if it has a dryer, I think that is the only thing that needs to be "sealed" the rest of the parts just need to be capped to keep critters out of it.
new parts do have tighter seals on the compressor, because they pre-oil so it doesn't come out. but just plastic press fit caps on everything else.
Thanks for the reply. When you go back together, what is the cleaning procedure for components other than the compressor and the dryer, blow out with air, flush with some kind of solvent, ???
"We live in a time when intelligent people are being silenced so that stupid people won't be offended".
