Originally Posted by Checker
as a side note..as far as I'm concerned any and all who submit that a temperature of 210 is fine to run an old engine : don't bother. Not to be nasty but I'll never accept that and submitting and reading is a waste of time for author and reader.
Just another side note..IF 210 was fine..then why only a max of 195 thermostat. is available. New engines have different cooling and pressures to run at.
lol....You do understand that 195 is the temp at which the stat STARTS to open....right???
