I used a 26" small block aluminum radiator from us radiator, https://usradiator.com/ . It has stamped aluminum tanks so looks kinda stockish once painted black and the factory shroud bolted in place with no mods. It is a 2 row and keeps the 340 cool no problem in S Florida heat. It is the same one that OER sells.
