You can drill it but the total size of those holes does not need to be much bigger than the center hole of the fitting that holds it to the block. Some block fittings have a 3/8 square hole in the center others use a large socket and hove a round hole, the socket style flow better, as do the adapters with more holes. A little R2 x 3.1416 math will let you figure it out.
