Just found this in the 93 FSM. Temperature gauge Cold graduation 655 ohms Hot graduation 64 ohms Fuel gauge Empty 90 ohms Full 12 ohms Oil pressure gauge Low 100 ohms High 12 ohms.
So neither of the senders I have come close to the spec. for the 93. Going to look through my 77 manual now.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
