Originally Posted by pittsburghracer
Originally Posted by A39Coronet
I don't disagree with anything said but one thing to keep in mind is getting the coolant temp up to "hot" doesn't automatically equate to hot oil, and that's what you're after to get out the moisture. Ive seen folks run all Saturday never getting above 150* and then lean out to 200*+ for the trip from the ticket booth to the trailer at the end of the day. I can't imagine that does very much in that regard.
I heat soak my engine one or two classes before I’m called then again in the lanes. After I make a 1/8 mile pass I turn off my water pump and can driving back to the pits. I burn 1/2-3/4 gallon a pass doing this after first fire up.
Same here John, keeps the oil hot and I'd rather have to try and get rid of coolant heat before a run than race against the clock trying to add it in. Boils the water out all day long.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
