I've run and reused composite head gaskets. Tried that once with the old steel shim type (OEM BB ones) ended up blowing one.
Copper head gaskets can usually be annealed and reused, which is probably what Sox and Martin was running.
My flathead ran an embossed copper head gasket, but they are no longer available, except NOS.
