Sounds like I should probably give them another chance, but I get tired of the "all numbers, nothing technical" approach real quick.
I should be good for a couple shows before I move on, so that's good...thanks for the heads up.
That my opinion too, too much about "numbers" and not enough about technical of building the car.
The useless "all about Mark" banter is why I record it and fast forward through it.
The show is more tolerable than it used to be, but still needs work.
I quit recording it for several years simply because I could stand listening to Mark's BS.
