Quote
I want to use an electric pump, Carter 4601HP, so a low pickup is desirable.
You do not need a low sump for these pumps, using your stock pickup will work just fine. The pump should be slightly lower than the fuel level but they still work fine if the pump is mounted beside the tank. You just don't want the pump to have to work too hard on the suction side, that's all. There have to be thousands of these out there in use with stock tanks and pickups. Don't waste your money.
