Originally Posted by 493_john
Originally Posted by dvw
Originally Posted by birdtracker
Doug can you post a picture of your shut off.? Birdtracker
The cable goes into the car where a lever is attached to the cage. It can be shut off from out side the car (rod in lower part of the pic) as well. The bell crank is just 3/8" steel tube. A compression fitting cut in half locks it to the switch.
Doug
Their is value to this on a street car as well. If I had a dime for every time I got in the car and forgot to turn the switch on......
John you are not the only one who does that!!!Lol Doug thanks for posting. Birdtracker
