Originally Posted by birdtracker
your valve covers are on the wrong side. Put the breather at the front. Leave the oil fill in the back and put another breather at the front. Birdtracker
I'm not sure how much improvement that will make on a 5300 lb Imperial but I'll flip 'em around when I add the internal baffle to the old PCV hole.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
