Originally Posted by John_Kunkel
The pump is capable of putting out over 300 psi at idle so it's not a lack of pump capacity. The regulator is the key.
Some full-race VB's regulators are set up to over 200 psi line pressure, not sure how it's done.
John is you talking about the stock pumps for the 727/518?
Op consider this a bump i'v been keeping scope on this thread i'm also curios about line pressure too.
