line pressure,(518 46rh)
i have a direct gauge on my car to check LP, it had 70psi in 1-2-3 gears at idle. i manually activated the kick down lever, it had 110 at idle,
i have a 3800lbs car with over 700pound feet of torque.
i want to ad LP. when i backed the adjuster screw out 2 full turns the gauge starts to flutter 70-90 1-2-3 and 110-120 with KD activated, all at idle.
what can i do to add psi but stop the fluttering.…
trans-go kit in VB
also, no psi in p-r -n at idle
What engine speed did you experience the flutter ?
Record that speed, the raise the engine speed higher with the lever back and report back - still fluttering? Less/more?
