Originally Posted by shanker
I ended up using this stuff to glue it back on the pickup
https://eclecticproducts.com/product/seal-all/
The glue you attached a link to clearly states it is only gasoline resistant. That mean it will likely never last fully submerged.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
