The point Joel and I are making is that a 93 donor isn't going to get you much in improvement. It's basically identical suspension and brakes, just rebuild what you have. The donor is probably going to need that stuff too anyways.
There's enough difference in wiring between the eras that you might be better off with a universal kit.
Ac, cruise, power windows etc are all available in aftermarket form.
For body panels, the fenders need to match the doors, the core support and grill needs to match the fenders. And grill needs to match the core support..
Fwiw, I think you're better off fixing your existing truck, swap in an automatic and go from there.
