Originally Posted by Azzkikrcuda
No issues with the driver. I measured another input shaft and support bore and they were the same as the one I am assembling. I suspected it was the Bushings not being correct diameter. Now where to find bushings that fit correctly.
How much smaller is the bushing than the input shaft?
A few thousands can easily be removed with a brake cylinder hone.
