Hello all. My '70 Hemi RR had no tach in the dash that came in the car. The car was purchased as a rolling shell from R&R salvage, a big Mopar collector/yard back in the 80's-90's. The dash could have easily been swapped out before I got it. I had no build sheet, only the fender tag. With that said, I did not put a tach in the car. Everyone who sees it is in disbelief that a Hemicar would not have a tach... I tend to agree. Any thoughts? If others have seen '70 Hemicars with no tach then I will probably put a period correct tach on the column. If not then I'll correct the mistake and add the option.
