Steel place down the street has a bunch of cut off remnants. Almost every piece is 48" or under. (So basically all built out of scraps). It was $237.40 for the material and I had the casters off of a cart that I cut up. Knocks down to dozens of pieces. Oh, and a tip number all the pieces. Helps make it is easier to go back together.
