THE more comfortable you are... the better you will drive...
Everything is adjustable up to a certain point. IF building a new car, make it like you want it, if you bought someone elses car....make it like you want it.... It will go a long way to making good passes when you are perfectly at ease in the car
....BAD A$$ STREET CAR.....
