if you run a manual valve body you should have a trans shield for your own safety and others spectaters or passengers !
What The Frick are you talking about? I've used reverse manual shift valve bodies on the street and strip going back to the late 1960s with no issues ever 727 started exploding when trans brakes were invented and installed
