Having 2 cudas and 1 cuda with this is excellent, sure beats just putting it in drive and going. it gives you that clutch-less shifting and keeps your arm moving..I love mine.but you need a good shifter and after awhile it gets to be normal driving, you can shift normally at the right times or you can get on it with a more aggressive shift..It sure beats the same old thing, plus it will not need the kick down linkage.
