do you have the headers you are going to run ?
if so, they should tell you if they will work with straight plug boots.
if you do not have the headers, i would wait until you do. then buy plug wires with the correct ends that will work.
don't be surprised if you need a combination of various ends so the boots do not touch the pipes.
beer
