Originally Posted by justinp61
Originally Posted by TruPerformance
Here is the best solution that I found for doing this: https://www.summitracing.com/parts/mor-74107
The instruction sheet is on the site to show how to wire it in. There may be cheaper versions of solenoids, but I went this route knowing that Moroso made this for doing exactly what I wanted to do.
I have the Painless version in my Dart.
Why buy two parts when one will do the job?
Or are you only using one relay with a switch?
