Used one from an Exploder in my Wrangler. Came with a 4.10 L/S, disc brakes. Strong unit, great swap that uses the same wheels. Would recommend this rearend, it takes a lot of abuse. It takes 33" tires hill climbing and pedal to the floor. It should hold up perfectly fine on the street.
