Flat faced lifters.. goes against saying lifters have to have a crown don’t it.
I corrected my post, the lifters I have appear to be flat as described. The cam they ran on (low taper lobes) have wear across the whole width of the lobe but has a higher wear pattern to one side.
I corrected my earlier post where I said the lifters were not flat.
We cool, reason I’m asking is I have a set of Hemi solids (original) that I got in a package deal that are flat and look like new, was going to send off to reface but if that’s the way it’s supposed to be I’m happy.
When I checked my parts I find that the Mopar solids from back in the day are flat faced. In original packages that I have. I checked a few sets. So it sounds like you are golden.
