. Depending on how much exposed steering shaft exists below the column housing you can cut it off and add a DD slip joint from there to the shaft/box coupler. If not enough is exposed it may be possible to disassemble and install it mid span between the upper and lower support bearings in the column housing. Or find one from a later model as stated by others. If you make a DD slip joint, with the shaft at its installed length install a nylon screw from the outer DD into the inner dd to keep it from moving in and out
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
