Originally Posted by csk
Holley has everything you need , have seen people use the HP efi, terminator uses the same HP ecu IIRC just a little different software
be carefuel here, the terminator and HP use the same ecu, the terminator is not potted ecu (if this matters to you) . ALSO the BIG little detail, the terminator X is not the same as the terminator / HP. it is not nearly as good.
