Holley has everything you need , have seen people use the HP efi, terminator uses the same HP ecu IIRC just a little different software
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
