Originally Posted by DusterKid
Originally Posted by NITROUSN
On my cars I always get it as far away from the supply port as possible. I also extend it down into the fuel about 3 or 4 inches from the bottom of the tank.
What do you use to extend the line? Alum fuel line?
It is your choice, soft aluminum tubing flared to AN 37 degree flare with a AN female fitting or AN hose with a female fitting on it work up scope
I haven't ran the return line on my new car yet but I'm thinking a aluminum line ending up about two inches from the bottom wrench
