The KB Hypereutectic are slightly less expensive (most listed prices do not include piston rings), but use the wider 5/64", 5/64", 3/16" ring pack
The KB 400 is sort of like the ICON 687, but compression height is less at 1.908", and dome is a bit larger so -6cc overall chamber difference. Overall the compression ratio is just a tad higher than the ICON 687. My sample calc = 9.5298:1 compared to the IC 687 = 9.4793:1
At only $376.99 This would be the best piston for the cost. For a mild build like yours, this would be a good choice if using head with 80+ cc chambers.
https://www.summitracing.com/parts/uem-kb400-030/make/dodge
