Hey Everyone
Haven't been on here in quite awhile and thought I'd check in with a ring question. I'm refreshening my 408 stroker and I'm stuck with deciding on what ring to run. It's .030 (Scat Stroker Kit) and I'm still running my KB744 or I'm hoping as I haven't pulled them out yet. I had a issue with my Evac system and the diaphragms broke and instead of drawing pressure out of the engine it did the opposite. I think my cylinders are probably highly polished as I can turn a fresh oil change black in a matter of a few passes. What's a good brand and should I run Moly top ring set?
