Originally Posted by Cab_Burge
What year Satellite?
Pre 1968 or maybe 1969 had solid inner shafts, not the later collapsible safety type. scope
If it was me, I would remove the 4 bolts holding the thin floor dust cover and loosen up the two nuts holding the upper steering column to the dash and slide the complete shaft it back a 2 to 3 inches up twocents
I've had the power steering shafts extended inside the columns also to make them look stock work scope up
Good point on the solid shafts. I'm sure that the collapsible started in 1967.
[img]http://i.imgur.com/boeexFms.jpg[/img]
31 Plymouth Coupe, 392 Hemi, T56 magnum
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
I don't regret the things I've done. I only regret the things I didn't do.
"Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
