I have an 800cfm AVS2 carb, manual choke. I'm wondering if I can add a Carter choke pull off and thermostat to mimic the factory 70/71 setup. Has anyone tried this? I'm not sure why but Edelbrock says that you can't add an electric choke to their manual choke AVS2s. They seem to have the same brass plug as the AFBs (not just leaded over) and the bosses are there where the pull off should mount. Can I run the pull off to ported vacuum and bypass the choke port? Both the pull off and thermostat are reproduced. I might have a hard time with the choke shaft lever, not sure how compatible the newer and older shafts are.
