i've done the buy paint and spray it on and rattle can. pro's and cons either way you go. last two i did was plastikote rattle can and it did what i wanted. i'm not sure there's any paint out there that will 100% protect against hot anti-freeze or hot alcohol gas. best bet is to be pro-active with leaks.
