I put a 4.5 pound lithium on the inside of the frame rail, under the drivers side floor. I mounted the master switch there as well with a remote control rod protruding thru the back of the car. Less cable = less weight and less voltage drop.
Kind of liking this ideal i'm in need of a battery for next year anyway . plus the ideal of less voltage drop is a win ,win Good post.
