Originally Posted by dOc - 3.0 !
fOcUs on the question tsk
The 12633 spec AND reasonable pricing !
Maybe you should focus on the answer of
Quote
The simple fact is, they can not require you to use any specific oil unless they provide it free of charge. It is against the law. The recommendation is 0w-40 synthetic in the manual. If you use this, regardless of brand or MS spec number, you are still covered under the warranty.
Kayse can't keep up at all now. lol
