Saw a few valve cover gaskets cause this where they stamped the terminals. Newer gasket they improved it. I’ve also drilled a very small hole through the stamped part and soldered it when parts were not readily available…. I’d also ohm out the injectors while you’re in there. A shorted one will kill voltage to three of them as the driver circuit is separate on 1-3 and 4-6.
