Originally Posted by todd440
Not sure if you found your answer yet, but the retrofit pans are the same, it's the oil pick-up tube that changes with the later vvt engines. Since the Holley pans come as a kit, you'll see them advertised by vvt and non-vvt, which is just a way to describe early versus late engines.
09 and up with Eagle Heads are VVT
Facts are stubborn things.
