I have a mismatched set of parts, and can't find the correct hose for the pressure side hose from pump to gear.
Wondering if I can cut the end off and connect another end with a short piece of hose and clamps.
I know the pressure is ~1000 psi, will this work?
Going from a 76 Saginaw box that needs a 0.3125 male with o-ring to a Borgeson box that needs 0.375 female flare
Can't find a stock hose in this configuration. Just need a short term solution before changing out the whole set-up.
Thx
