I did it. I lower it to where I want it. I didn't slam it to the ground. I still want to use it as a truck. I installed an 8.75 3.55SG with 11"x2.5" brakes and did an axle flip. I built a set of leaf springs and use that to set the rear height. In the front I cut a coil. I also added a front sway bar. I still need to go through the front end but for the most part I'm done with the chassis work. It corners and handles much better. Is fun to drive.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, .
Moparmarks Parts & Restorations
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/motormangj@gmail.com
