On another note, I did put a 3/4 ton small diameter, double diaphragm booster on a Ramcharger years ago. Not sure if those are just as hard to find? I guess you might need one of them anyway, if your installing a RB engine, just for clearance to the valve cover. That is, if you don't go the hydroboost route.
