Maybe the converter is junk.
that would be my thinking. It's a nonmagnum 360 that ran good when pulled(no vibration I'm sure)harmonic dampener wasn't changed(would be no reason to), the correct flex plate(The one for an externally bal 360 with a neutral 727 converter) was used. R&R the converter.
