Mine has had the same optima red top in it since I put the car together 8 years ago. Car sat in the cold all winter, and I didn't even have to charge it this spring....just fired right up.
But power draw is probably a bigger issue than capacity. If you're taking out more than you can put in, it'll die eventually no matter how good of a single 12v you put in.
