I have two truck a 86 and a 73, the 86 had the big tie rod ends the 73 has small. They sent me the big drag link, if worst comes to worse I will order two bigger inner tie rod ends. Both are two wheel drive, it will really get confusing when I put the 63 cab on the 86 frame with the 73 spindles and rear end. runaway
56 Plaza 63 D100 step side 67 Coronet, 68 Roadrunner, 69 Super Bees, 69 Coronet 500 convertible, 70 Roadrunner Post, 79 D150 360, and a severe case of Mopar a,d,d
