For lifting new hemis I took a piece of angle iron, drilled a hole on each end to bolt it flat to a head via the intake bolt hole and drilled a bigger hole in the center for the tip of my cherry picker hook, very low clearance set up so I don't have to pull hoods or have the cowl in the way, done a bunch this way with no problems so far.
