Originally Posted by INTMD8
[quote=Pacnorthcuda][quote=GTX MATT]Dyno results through an automatic can sometimes be misleading, especially with a higher stall converter. Some produce realistic results, some read super low.
Or, going from a less to more efficient converter with no other changes can result in much higher numbers with no other changes.
Torque converters can make so much difference in the car performance that is is hard to believe until you test several different ones or see someone do that at the track.
the last converter swap I did was from a custom built 10 inch street and strip Contintental to a 8 inch SS Hemi Turbo action, that swap made my car pickup .2 ET in the 1/8 mile and gained 2.0 MPH shock scope
We've seen .8 ET gain and very little MPH loss going from a stock 11 inch street Hemi converter to a custom built 8 inch Rossi race converter in the 1/4 mile up
The bad side of different brands is also possible, GER were junk down The first 8 inch race converter we bought and used was a Art Carr 8 inch race converter for Hemi NHRA stocker, it would slow the car down 3.0+ MPH and .3 ET in the 1/4 mile from the stock 11 inch street Hemi converter whiney puke down
