how did you drill out the spring perches im not quite sure what you did there? any pics ?
The 8 3/4 rear end I put in the Cordoba had a small hole in the center of the spring pad . I just took the housing to a machine shop and had them drill the small hole out to 1 5/8" or something like that. The 7 1/4 rear end that was under the Cordoba origonally, had a large hole in the spring pad. I measured the size of that hole and had it duplicated on the other housing. Does that make sence? With the large hole in the 8 3/4 spring pad...it just bolted up to the car like the stock rear end did. It was really very easy.
I just sold the rear end a couple weeks ago or I could take a picture for you.
