I have not gotten this motor apart so I can’t tell you the clearances yet. And yes I’ve heard about how careful you have to be with clearances on these pistons. End gaps, skirt clearance, etc. I don’t use cheap pistons. My shop won’t either. I’ve know half dozen of my friends who have tried them and they have failed in some for or another. And you are correct, some shops can’t get anything to work right. This is the fifth motor in a row that I have built that some other shop has done something wrong and the engine has failed. And they are coming from all over. I got a 68 440 in a trade deal the other day. It’s still together. I pulled the valve covers and noticed that the oiling holes on the rockers was install UP! What a shame. My shop was started by an old Super Stock racer who built race motors to keep his race cars going and ended up a really good business. To answer your question, though. The piston broke where the valve relief is cut at the rings. It is cut way to deep, in my opinion, for a hyperutectic piston. They are not meant to be as strong as forged. One good thing. It broke apart in a million tiny pieces instead of staying one big piece and punching a hole in the head. I’ll post a picture from my phone.
And before someone says detonation problems, none of the other pistons showed any signs of that. I thought that at first until I realized that the debris had bounced around through the intake plenum and blasted the pistons that on the same plane of the manifold.
Yep, not enough ring gap is common cause for that type of failure. It's not cheap pistons, it's poor attention to detail and following instruction. The old .004 per inch of bore doesn't work on KB hypers.
Used a bunch of those same pistons and juiced that bejesus out of them with no issues. It's not the piston IMHO.
Again, we’re just guess with our prof. I don’t believe in cheap parts. If I remember correctly, when I bought my headlight relay kit from you, you said you chose to buy better relays because they did not give you trouble. That I respect.
Yes and the reason is failures on the cheap relays.
Never had the issues you've seen on my stuff using those pistons. Don't know the answer for your experience. That piston damage is a classic not enough ring gap issue. Std piston gap 4-4.060 bore .016-.018, KB's need .026-.030 for the same bore.
As I say all the time, "Pick your parts, Pay your money." Use what works for you.
All good here, hope things go well with what you are working on.
