Originally Posted by pittsburghracer
Originally Posted by 68LAR
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers
Pretty common problem(probably the most common aluminum head welding repair).
Somebody fairly close to you should be able to take care of it.
. Thanks for the info. I don’t have any connections around here for aluminum welding. I’ll have to look into it tomorrow. Plus, I’m sure the head will need machine work after the welding. Thanks again.
I’m sure Tom Hemphill could fix you up but I’m not sure how long it would take. An old timer down by pittsburgh mills mall could probably do it in a day or two. Let me know if you need his number. He can’t machine it but he could weld it. This guy has some interesting history and stories to tell
. If you could, send me any contact info you have. PM me. I’d like to find a one stop shopping place, I’ll take anything at this point. This will be my first rodeo.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
