Originally Posted by fast68plymouth
Originally Posted by 68LAR
Can aluminum heads be welded? There is about a 1/8" deep by 1/4" wide channel between the two inner combustion chambers
Pretty common problem(probably the most common aluminum head welding repair).
Somebody fairly close to you should be able to take care of it.
. Thanks for the info. I don’t have any connections around here for aluminum welding. I’ll have to look into it tomorrow. Plus, I’m sure the head will need machine work after the welding. Thanks again.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
